unstyled AR first reduction gear bearing
Don R
05-10-2007 10:22:37
I can not get this bearing to come off the shaft,it is loose around the out side and spinning.I am hopeing I dont have to remove the reduction gear cover.Shurly someone has a trick for doeing this.I need all the help I can get. THANKS IN ADVANCE DON
Mike M
05-10-2007 11:01:46
 Re: unstyled AR first reduction gear bearing in reply to Don R, 05-10-2007 10:22:37
Did you try taping the shaft back ? There is usually some play that way for the shaft to move. It may have to be in either high or low or neutral or something so as to let it move more as one of those gears engages directly onto that input gear.
