I have a 1951 John Deere A w/ a blown exhaust manifold gasket. From what I read and can see, there is two ways to approach the repair. 1- Remove hood, fan shaft, etc, and leave the head on the tractor. Or, 2- remove the head with the manifolds still attached thru the tractor frame. I believe the valves are ok on this tractor, but a leakdown tester has revealed that I do have considerable piston ring leakage on both cylinders. There is considerably blow-by thru the oil filler cap while the engine is running as well. Is blow-by normal for this tractor? Power seems to be ok. Back on the farm in the 70's, we had a 1951 A (same as this tractor), and ours had a problem with breaking the compression springs inside the governor housing on the fan shaft. So here's my questions- 1- Would it be wise to to do the "pull the fan shaft" route and replace these springs while I'm doing the manifold? 2- Or, should I pull the head and then also pull the pistons to survey the situation, and then just wait on those compression springs IF they ever fail? 3- Or, basically do both? I don't have lots and lots of time for working on this tractor, but I do want to be sensible about this too and not regret that I took the easy route. Thanks in advance for quality answers!
