1967 Stanadyne DB Rebuild Needed: Advice....
George in Georg
05-10-2007 07:25:13
third party image
1967 John Deere 2020 with 'Stanadyne DB'.
Tractor now runs great (knock on wood) since cleaning out a small amount of 'coffee grounds' stuck in the return line fittings.
Two questions:
1) I am very mechanically inclined (I rebuild automatic transmissions) and feel I could rebuild this pump. Who sells a complete rebuild kit?
2) If self-service is very strongly advised against, where is the best/most reasonable service center to either get this one rebuilt or exchanged?
Thanks!
Mike M
05-10-2007 12:54:11
 Re: 1967 Stanadyne DB Rebuild Needed: Advice.... in reply to George in Georgia, 05-10-2007 07:25:13
If you do do it yourself don't remove the advance piston ( if you have one ? )to put a new seal on it as it is not a seal but more like a metal piston ring and you can't get it back in without a special tool. Even the pump shop guy broke one for me while try to put it back in,then I didn't feel so bad.
jdemaris
05-10-2007 11:52:59
If you're a pretty good mechanic there's no reason why you cannot do it yourself. The only special tool that you absolutely need is a Bristol wrench. There is one bolt in the pump that . . . when used in other applications e.g. Ford, Allis Chalmers, etc. - takes a standard hex Allen wrench. But - in Deere applications - takes a splined Bristol wrench instead. Deere or Stanadyne part # 15499. Some people have ground down an old Torx bit and made it work - but I never had to try it - since I've got half a dozen of the correct wrenches. Fuel delivery can be set/checked with a 2" micrometer - set rollers to 1.967" There is no such thing as a rebuild kit. A new seal kit is $12. At the least you will also need a new brass bushing in the drive-end of the pump - called a Pilot Tube for $6. Also good insurance to buy a new metering valve since it is a moving part and wears - cost $12. Also new pump blades for $12. And - about the plastic ring that is broken. A new one comes in the $12 kit - but you can update and eliminate it for an extra $35. For automotive use, it was totally eliminated after 1985. Timing advance can be checked/adjusted with the engine running. DBGFC431-2DH or 25AJ - fuel roller setting 1.967" Timing mark etched at 138.5 degrees. Timing advance - 1 degree at 600 pump RPM (1200 engine RPM), 7 degrees at 1000 pump RPM, and 8 degrees at 1250 pump RPM. Later 2020 pumps - JDB431AL2408 or 2731 - rollers set at 1.972", and timing advance - 1 degree at 400 pump RPM, 5 degree at 850 pump RPM, and 8 degrees at 1325 pump RPM. For somebody with experience, it takes less than an hour to completely go through the pump - not including taking it off, and putting it back on. If you take your time, and even if you spend three hours - you're still way ahead - mostly likely repairing the pump for around $50 in parts. In regard to the Bristol wrench - if you cannot get it from Deere, any good pump shop will sell you one - or - go on the Web to Bristolwrench dot com.
third party image
third party image
third party image
third party image
third party image
Glen in TX
05-10-2007 10:04:25
Talk to the service manager at your local JD dealer or other shops and ask who they use. They might even send it off for you if out of the area some.
Bob
05-10-2007 08:13:09
First, you need a manual and a couple of special tools.
Deere Techpubs has injection pump manuals, or look on ebay. IH Blue Ribbon Injection pump service manuals sell a LOT cheaper on ebay than the Deere manuals, and cover essentially the same pumps, giving teardown and assembly information, with the torque values you need.
One tool that is REALLY tough to get along without is a sleeve sort of thing that supports the advance bolt ball-thingy so it doesn't split open while you wrench it loose or tight.
You can get the seal kits for $30.00, or so.
You CAN do it yourself, IF you keep things clean, and DON'T touch any of the adjustments. Be careful that the rollers and "shoes" and plungers in the hydraulic head stay in place, and don't fall out and get mixed up, so parts that have been "wearing" together stay in the same orientation.
George in Georgia
05-10-2007 12:52:20
 Re: 1967 Stanadyne DB Rebuild Needed: Advice.... in reply to Bob, 05-10-2007 08:13:09
Very good replies, have saved all in a Word document for reference. Surprised to find a Stanadyne dealer very close to me.
Thanks to all!
