front pedistal
kendak
05-10-2007 06:41:52
When did the Unstyled "A" go from [4] bolts to [8] on the front ped....thanks ...KENT
kendak
05-11-2007 08:55:05
 Re: front pedistal in reply to kendak, 05-10-2007 06:41:52
misread your post sorry...this "A" had a front post with [8] bolts in it when I got it but I broke this post when I pulled it out of a weed patch with a trackhoe...I put side pressure on it & should not have...I took replacement ped off parts tractor but it has only [4] bolts serial plate is gone so I don't know year...tractor I'm trying to run is 37 model...thanks for help ...Kent
40 JD G
05-11-2007 14:54:05
 Re: front pedistal in reply to kendak, 05-11-2007 08:55:05
I know the styled A's have a 8 bolt front end, i just switched out a late A with a wide front and it had 8 bolts, hope you find something that works.
kendak
05-13-2007 10:41:52
 Re: front pedistal in reply to 40 JD G, 05-11-2007 14:54:05
found out that the "AO" & "AW" unstyled tractors have "8" bolts....that is the wide & single front wheel thanks ...Kent
40 JD G
05-10-2007 18:47:17
It was the unstyled B that changed from 4 to 8 bolt. The unstyled As were all 4 bolt. I think the Bs changed arouned serial number 2200 or so.
kendak
05-11-2007 08:24:52
 Re: front pedistal in reply to 40 JD G, 05-10-2007 18:47:17
Sorry but my 37 "A" has [4] bolts ...just took it off in rebuilding tractor as a puller & am worried about breaking front as I will be adding weight racks & weights...have already broken one with [4] bolts on this tractor...if I could find [8] bolt front I can drill front frame to match...thanks...Kent
