1946 JD A question
LDP
05-10-2007 05:28:19
I had trouble getting this tractor to run good. I found that the nut that holds the rocker arm bracket to the head had come loose and the valves on that side were not opening correctly. Both of these studs have lead washers on them. Is that correct or should they have regular 5/8 lock washers? The parts book looks like the lead washers are only used on the head bolt studs. These studs are the same one"s that hold on the valve cover. Thanks.
Mike M
05-10-2007 05:53:40
 Re: 1946 JD A question in reply to LDP, 05-10-2007 05:28:19
Regular lockwashers sounds correct. They then use a copper or alum. washer under the acorn nut for to seal the valve cover.
txasylum
05-10-2007 05:37:18
You need to use lead washers on the head studs.
txasylum
05-10-2007 05:37:15
LDP
05-10-2007 05:42:26
 Re: 1946 JD A question in reply to txasylum, 05-10-2007 05:37:15
I know the head studs need lead washers, but what about the studs that hold the rocker arm assembly on?
txasylum
05-10-2007 05:52:40
 Re: 1946 JD A question in reply to LDP, 05-10-2007 05:42:26
I just put my B together. I initially put locking washers on the studs for the rocker arms. That pushed the nut out too far so that the valve cover would not seal. I ended up just taking them off and not using any washers. I don't know if that is right, but it worked for me.
