First H....Maybe
Lane R
05-09-2007 18:50:30
So I found a real pretty '41 JD H getting ready to go up on the auction block and went to look it over today. In my course of looking it over I found a lot of loose play in the transmission shift lever. It would even move in and out pretty far. I was wondering if this was at all acceptable or if it was a depiction of worse problems (I don't want to have to do a lot of fixing, right now). Is there any opinions out there on this problem?
P Bronwing
05-10-2007 02:10:15
 Re: First H....Maybe in reply to Lane R, 05-09-2007 18:50:30
Lane -- take a short trip to the JD-H Restoration Site (below) and upon arrival, over at the left, one-click on GEAR SHIFT. Many John Deeres of the vintage 39 up into the late 40's were afflicted with the design such as the H had troughout its production life. The difference with the H is the weather boot fails to keep water from doing its damage. As a result not only is the boot lost, but also the fulcrum socket parts and its cover! It isn't terribly difficult, but a bit pricey because even the fulcrum ball may need a new one. It is not hard to spend upwards to $175 in parts, but once done -- it will be good for another 66 years! There are some recent after-market sources for some of these parts so if you buy the tractor & need to rebuild the gear shift, seek me out first -- I can point you to a savings of a few bucks here. (PatB)
Mike M
05-09-2007 20:44:23
That is a VERY common problem on those. So is water getting in around it and freezing and cracking the tranny case. Look underneath for any cracks, check the head and block over close too !
Paul from MI
05-09-2007 19:15:30
Probably just wear on the ball and socket of the gear shift lever. Parts are available(or were a few years ago) and it isn"t a hard fix. Only involves removing the gear shift cover plate from the transmission and replacing the parts. It"s a fairly common wear point on H"s. When you fix it be sure to put on a new boot to seal the gear shift lever.
Paul
