401 b lift problem
steve mcdonald
05-09-2007 18:22:36
Anybody ever had this problem.My lift will not come up,if you turn the steering wheel if come's up fine.It does not make any unusall noise's or sounds. But it does it every time. I bought it as is and was told it was the priority valve but there is not one in the parts list or manual,
scdeere1356
05-14-2007 19:00:31
 Re: 401 b lift problem in reply to steve mcdonald, 05-09-2007 18:22:36
Thanks guys I now have a direction to work in,
Tx Jim
05-10-2007 04:37:04
Steve,I think your steering valve is leaking internally causing 3pt not to raise. Have you felt for extreme heat at steering valve? Is tractor equipped with a frt. end loader? The pressure control valve(priority) is supposed to close at 1600 psi to give priority oil to steering/brakes when stand-by pressure has dropped significantly.
720 in pa
05-10-2007 03:26:16
the priority valve is mounted to the right side of the trans housing below the floor plate.it is a three bolt valve with a syteel line coming from the pump fastened to it.i would dissassemble it to see if theres anything wrong with it.if no problem in there,you might have a high pressure leak to return in your steering system
