2840 hydraulic trouble
Bob 666 A
05-09-2007 13:44:37
We plant with our 2840 and run an orbit motor on our dry fertilizer tender. When the oil is hot form planting it starts the orbit motor fine but after a bit the hoses start jumping and the auger slowes down. Stop it for a few seconds and it does the same again. We have lost hydraulics but get it back if we change the filter. Last time the filter was collapsed. Cut it apart and found very little debri in it. The transmission oil was just changed this spring but looks grey when disconnecting hoses. Any Suggestions? Thanks.
720 in pa
05-10-2007 03:14:07
 Re: 2840 hydraulic trouble in reply to Bob 666 A, 05-09-2007 13:44:37
gray transmission oil generally means a pump going out or brakes going out.yes if you are running a hydraulic motor you should have return to your filter
J Plunkett
05-09-2007 15:28:49
Cleal the screen in the trany it must be plugged up and your pump was sucking so hard to collapis the filter
cannonball
05-09-2007 14:31:05
How are the remotes fixed... do they return to the rear end or do they go into filter cover..for running hyd motors on these older Deere's you need the return oil to go back into the filter cover..I have bought a filter cover and just run a single 3/4 hose up to the back and put quick connect on it..hooked up return into it..that left the remotes as they were... the front pump will pump 25 plus gallons and trans pump will pump about 13 when new, also the trans fluid goes to the pto and hi lo then what is not used goes to the front pump... if return does not go into filter cover try that..
MAY GOD BLESS THE USA
