I have a John Deere 530 this is running rough and I need some help troubleshooting the problem.Prior to mid last year, it would start right up and run very well. It would run best with the choke pulled out about � of the way. It ran well under load but I did notice a lot of carbon build up on the spark plugs. Last year it started to run real rough and start much harder. I would have to have to crank for some time to get it to fire and eventually it would start. I also would have to change the plugs to get it started on several occasions. It has gotten worse and started to backfire and cough on a regular basis. I can not load it up for any length of time without a lot of backfiring and coughing. Initially I adjusted the load screw and really saw no improvement in the backfiring. Just last weekend I tried to adjust the idle screws, thinking it was running rich. I had a difficult time setting the idle with one plug shorted. I followed the process that I had found on this site from back in 2005. It seemed like it would be fine and I would short the other plug the engine would not run smoothly or it would die. I cleaned the points and replaced the cap and rotor last year and saw no real improvement. I have changed the oil in the air cleaner as well. I am beginning to wonder what I am missing. Could it be trouble with the float ? With the coil? Should I soak the carburetor in cleaner? I am looking for some advice on other areas to investigate. I am new to hobby and need some help. Thank you for your input. One other related question, can someone recommend the best JD sickle mower for the 530? Are there models I should avoid?
