DETRoit diesel 371 sitting for 10 years on back si
JOE e DIRt
05-08-2007 21:46:13
Ive come across a boat that has a detroit diesel 371 in it however its been sitting inside the boat on the back side of catalina for quite some time. Prior to being laid up the motor was rebuilt and has about 1100 hours on it. If this is the case should I have too much of a problem getting it going and making it last many more hours to come ? The owner of the boat is saying I only need to grind it for 30 seconds then let it sit for 2 minutes then repeat the process untill it fires up although I am concerned that it may not be that easy .
Motorken
05-09-2007 11:01:41
 Re: DETRoit diesel 371 sitting for 10 years on bac in reply to JOE e DIRt, 05-08-2007 21:46:13
Joe, I bought an old oliver 99 with a 371 that had been sitting for 15 years...I also have a few other detroits. I talking to the old timers they will advise that before trying to twist off one should pull valve cover and make sure rack is free and oiled so it won't hang wide open. Also be sure to check the emergency block plate on blower intake to make sure it is free and you know which is open and closed. The point of doing these minor checks is to keep the engine from hanging open and running wide open or backwards until it blows up. also make sure right visc of oil in air cleaner...they are great machines worth saving...
Steve Crum
05-09-2007 06:16:51
I would look the outside of the engine and bilge over closely for evidence of water before I went too far. A good tight boat will hold as much water in as it will out. The reason I know this is I went and looked at an old 20' Chriscraft mohogany speed boat that seemed to be priced too fair. "Only a little rot in the transom". This had been refitted at some point with a 327 Corvette engine. As it turned out, the boat had been left by it's previous owner along side a barn and the owner was ill. Snow and ice off the barn roof destroyed the tarp and the boat filled with water from the eaves of the barn. The guy's son was selling it and was hoping to find a sucker...err someone to restore it. As it turned out, he did find a buyer. A guy I used to work with. He pulled the engine out and what wasn't freeze cracked, was rust fused together, even the cast aluminum valve covers were cracked. Apparently the engine sat for quite awhile completely under water in the bilge until freezing water had pushed the transom away from the keel and the water drained out in the spring. The engine went to the scrapper and the boat became a beer drinking bonfire one night.
One expensive lesson. Look it over and hear it run before the cash comes out.
David Pearson
05-09-2007 05:36:48
The Detroit has a unique injector system that has the actual pump in the injector. If it gets fuel to the injector and the engine has plenty of compression it will start almost instantly when turned over. Bleed all the lines and filters to be sure there is no air in them. I've started the 71's after years of sitting with only a few turns till that welcome sound that only a two stroke diesel can make.
JOE e dirt
05-09-2007 09:56:19
 Re: DETRoit diesel 371 sitting for 10 years on bac in reply to David Pearson, 05-09-2007 05:36:48
Thanks for the replys , both sound like they could be possibilities but I would like to think that the bucket sitting on top of the dry stack prevented moisture from getting into the motor but then again you have through hull fittings also. The diesel was completely dry and there was no water whatsoever in the bilge.....
