jd2940
banjo
05-08-2007 20:28:33
cousin has a 2940 that you have to wiggle the gearshift to get it to crank over. how hard is this to solve and where would i look for the switch?
Tx Jim
05-09-2007 04:28:54
 Re: jd2940 in reply to banjo, 05-08-2007 20:28:33
If 2940 is open-station remove cover trans.shift handles stick up through. On SGB remove plate in floorboard. Safety switch is visable on top of trans. Try removing a shim and re-installing switch. Tx Jim
banjo
05-09-2007 07:21:05
 Re: jd2940 in reply to Tx Jim, 05-09-2007 04:28:54
there are not any surprizes waiting on me when i take the cover off is there? hate to work on other folks stuff for that reason. i do not want to get something apart and not get it back together. most of my work has been on the smaller farmalls.
no cab, just the canopy
Tx Jim
05-09-2007 10:17:28
 Re: jd2940 in reply to banjo, 05-09-2007 07:21:05
No suprizes. Just unbolt the cover and raise it up to see switch. Tx Jim
