4230 overhaul
PreciseFarms
05-08-2007 20:13:43
Dad has a 4230 syncro bought new in 1974. After 12,000 hours or so it is finally ready for its first rebuild. It basically has no compression and won't start. It probably never will have more than 200 hours a year put on it and likely won't get 50 a year. It will primarily be used for stationary PTO work (grain dryer, auger, fertilizer belt, etc.). So would an in-frame be the way to go or a complete overhaul be worth it. Also, he's leaning toward the JD kit or for the money would a short-line kit be suitable. Personally, I hope he goes with Deere for the kit since the quality will obviously be better and I hope to restore the tractor someday as its pretty beat up. Any opinions would be appreciated.
Maark
05-09-2007 07:25:28
 Re: 4230 overhaul in reply to PreciseFarms, 05-08-2007 20:13:43
Be sure the camshaft has been checked for wear at the oil pump drive gears. Your JD dealer will have the tool to check. The 30 series were known to have soft gears that would wear out and without warning the oil pump would quit.
MSM
05-09-2007 07:08:08
Either a JD kit or a kit from Clevite have the redesigned high ring pistons.The Clevite kit may be a little cheaper.Make sure you have the head redone by a reputable machine shop that has the specs to rebuild it properly with the correct valve standout,with those hours it will probably take a set of valves and seats.With the high ring pistons and a good head it should start unassisted down into the 20's.
Tx Jim
05-09-2007 04:35:17
As long as engine has no main brg problems or leaking rear main seal,an in-frame is all that's required. I personally would use JD parts or at least name brand parts. Tx Jim
