Adjusting Wide Front on JD A
Dan Oehmke
05-08-2007 18:39:15
Are the large pins used to adjust the width of the axle threaded into the tube? Or are they just pushed through the bolt holes? Also have the same question for the smaller screws used to adjust the width of the drag links --- threaded through the drag links or just pushed through bolt holes? What's the best way to get them out?
Thanks,
Dan
Ten-Twenty
05-08-2007 19:06:45
 Re: Adjusting Wide Front on JD A in reply to Dan Oehmke, 05-08-2007 18:39:15
Dan,
In both cases the bolt is simply to hold the pieces in place. There is a wealth of information in the archives about adjusting stuck (most of them are) wide fronts. Do a search and happy reading.
Ten-Twenty
05-08-2007 19:11:49
 Re: Adjusting Wide Front on JD A in reply to Ten-Twenty, 05-08-2007 19:06:45
Dan,
Sorry, I misread your question. The bolts are NOT threaded through the holes. They are pushed through and then have nuts attached on the opposite side. They will need to be pushed out (be careful not to ruin the threads).
Dan Oehmke
05-09-2007 04:15:26
 Re: Adjusting Wide Front on JD A in reply to Ten-Twenty, 05-08-2007 19:11:49
Good to know the bolts don't need to turn out. Thanks!
