Blake you didn't give us much to go on. ~You might also have more than one problem there. ~You say...."But if I disengage it again while in gear, and pull it out of gear, as soon as the gear comes out the clutch starts spinning immediately, even though I have the clutch handle pulled back as hard as I can"..... Answer, that usually indicates a pulley brake that is adjusted WAY too loose...If that pulley brake isn't set tight enough it allows the hand clutch lever to pull the pulley in & re-apply the clutch disks. The harder you pull on it the more the clutch re-engages.....Start with a clutch pulley brake adjustment. ~Another problem you could have is a worn operating sleeve drive pin [or pin hole] in the pulley that allows the operating sleeve to spin slightly & not keep the toggles in line. ~You could also have step wear on the sides of the 3 adjusting bolts that allow the bolts to bind up in the pulley holes when put under a load. ~Another contributor could be excess crankshaft end play. If the crankshaft moves latterly very far it could effect the fork's ability to control the clutch. ~Where is the wear on the clutch driver? If between the crankshaft & driver that clutch will never operate correctly. If between the disks & driver it should still function pretty good even with some wear in that area... ~If you can give us some more history on your clutch problem & when it started & how long it has acted up we can get a little closer on the problem for you.. [email protected]
