bushings
kendak
05-08-2007 07:48:42
I need wrist pin bushings for a 46 styled "A"...local dealer doesn't have a clue ..can anyone help?..thanks ..Kent
Sam in MN.
05-09-2007 11:06:01
 Re: bushings in reply to kendak, 05-08-2007 07:48:42
I just rebuilt a 48-A and the bushings were available at my local JD Dealer. If the dealer is worth anything, they will be happy to order them for you and it only takes 2 - 3 days. I believe I paid like $28.00 ea.
Find another JD Dealer and be sure to tell them why you are taking your business elsewhere.
Bob in KS
05-08-2007 16:27:47
I"ve had the same problem with a dealer near me Kansas side of Kansas City. They seem to know next to nothing about any John Deere"s produced before 1980. I went in once for a air filter for a 110 riding mower. They tried to give me one for a L110. Another guy even told me that they weren"t supposed to order an old part for my 38 A when I brought the part number in. I just go to the one a little further away that is an agricultural dealership. They are much more pleasant and always pretty much know what I have and make sure I"m getting the right part for my stuff.
Henry M
05-08-2007 08:51:55
Kent
I don't understand about your dealer. All that stuff is in the JD parts database. I would be real disappointed if the dealer I went to acted like that.
Glen in TX
05-08-2007 08:11:18
Go to another dealer or ask for a parts person that can find the styled A parts catalog and look it up for you! They are still available according to JD parts online. Measurements are there too so you could even make your own.
A727R for styled A up to 487999
A2343R for A 488000 and up
Part Details
Part Number: A727R Part Price: 26.22 USD On Hand: 0 Check Other Stores Description: BUSHING,PISTON PIN
English Metric Specification Weight 0.57 LBS 0.26 Kg Inside Diameter 1.607 IN Outside Diameter 1.941 IN Length 2.000 IN Hole Location 1.000 IN Code Hole Size 0.500 IN Material 660 Finish Note F
Part Details
Part Number: A2343R Part Price: 30.23 USD On Hand: 0 Check Other Stores Description: BUSHING,PISTON PIN/PARTS ONLY/
English Metric Specification Weight 0.31 LBS 0.14 Kg Inside Diameter 1.752 IN Outside Diameter 1.899 IN Length 2.000 IN Hole Location 1.000 IN Code Hole Size 0.438 IN Material 660 Finish Note F You can get a parts catalog for your A PC675 from JD publications 1-800-522-7448 or http://techpubs.deere.com
kendak
05-08-2007 08:44:49
 Re: bushings in reply to Glen in TX, 05-08-2007 08:11:18
thanks ...Kent
