'42 B Powerlift Froze Up
SWagner
05-07-2007 20:18:10
Before I tear into the Powerlift unit, does anyone have any typical causes for a Powerlift not operating? The tractor had not been run, or maintained, in the last 2 years before I acquired it. I changed the fluids (30w) and only dropped 2 qts of old foamy oil with the change. Engine does not load when engaged, and I have tried to manually move the rockshaft - no success.
dds-inc
05-08-2007 08:19:28
 Re: '42 B Powerlift Froze Up in reply to SWagner, 05-07-2007 20:18:10
I hope you know the PTO has to be on in order for it to operate.
The reason you can't move it is probably because there is a bid spring in the shaft. try using a cresent wrench with a pipe on it to move it.
SWagner
05-08-2007 08:27:56
 Re: '42 B Powerlift Froze Up in reply to dds-inc, 05-08-2007 08:19:28
Thanks. The PTO was engaged and working and I did try a wrench and cheater to move the shaft - up and down - nothing.
F-I-T
05-08-2007 10:33:25
 Re: '42 B Powerlift Froze Up in reply to SWagner, 05-08-2007 08:27:56
I remember a during a past time when this powerlift-no-go problem came up, and the prior owner had removed one of the pump gears. That one took a while to convince the new owner that that it was a possibility he had to consider.
So, you have to consider that the pump is missing a gear, and next consider that a check valves is stuck open (located underneath, but unlikely since this would probably allow it to lift but not stay put), or a stuck open, or broken spring in the relief valve (pulley side, good possibility).
You might find some bad, bad filth in there. I wouldn't be afraid to flush it some more after checking those those valve/check points.
Frank
