4020 oil capacity without filter change?
Nylon
05-07-2007 19:57:21
My Book says that the 68 synchro takes 8 quarts. I did 8 quarts and I did not swap filter yet. Wanted to do kind of an oil flush. Oil on stick is a bit high and it is a hard start. I am thinking I best not run it and do the next change with filter.
Nylon
05-08-2007 20:22:05
 Re: 4020 oil capacity without filter change? in reply to Nylon, 05-07-2007 19:57:21
Thanks for the info guys. I did check oil at thread tops and not screwed in. I will check my batteries tomorrow and see what they are charged to. It seems that the starter crank rate is kinda slow on the last 2 starts and we are in the 70's. It has turned over faster at 28 degrees. This slow turnover became noticable right after the oil change so I got a nervous bug in my shorts. I checked oil level after the first slow start and it had splashed up the dipstick rod quite a ways. The oil level cold is above the full mark a tad only and tractor is slightly inclined in its park spot to that direction.
msb
05-08-2007 17:42:33
I don't think the oil level is causing your starting problem nor do I think it is so high as to cause a problem. Only when the crankcase is fill so as as to cause the rod caps to dip in the oil will it cause a problem. That can cause some oil to foam. That foam can cause under lubrication of rod and main bearings due to air in the oil. 8 quarts is not even close. There has to be a good deal of clearence due to operating engines on inclines.
Mike M
05-08-2007 06:14:45
A bit high ? how much is a bit ? I would doubt even an extra quart would make any differance to harm anything. Too low is going to do more harm. You need to check the oil with the stick resting on the threads and NOT screwed in. I've heard tales of those engines locking up when someone got the front end stuck left it run and then went back for help came back and engine was locked up because the oil went to the front of the pan and was also low. I had the oil light come on ours once using the loader on a hill pointed down and the engine oil was at the add mark or a bit above.
