G main bearings
Merf
05-07-2007 19:04:55
We are going through the motor of a JD Model G, serial #333xx. We have repaired the head and block. However, the crankshaft is causing some problems. The only main bearings we can find are JD standards. The main journals on the crank will be clean at 8K. The question is, will these standard main bearings, when shimmed per the IT Manual, be compatable with 8K cut mains? How many thousands can be cut from the crank and standard main bearings be utilized? Has anyone had a crank shaft sprayed and or welded and ground back to standard?
teddy52food
05-08-2007 19:05:54
 Re: G main bearings in reply to Merf, 05-07-2007 19:04:55
I think you will have to get it ground to .010 & get .010 us inserts. Check with your machine shop.
