John Deere Model 317 tractor
99flatirons
05-07-2007 17:22:54
I have a model 317 J D garden tractor, and when I'm mowing the lawn, the mower blades start and stop by themselves as I'm mowing. After a while they stop completely. They stop and start in very short intervals like ten to fifteen feet of mowing. The switch has been replaced.
Thanks all
Herny M
05-08-2007 08:57:26
 Re: John Deere Model 317 tractor in reply to 99flatirons, 05-07-2007 17:22:54
Run down the wiring harness for a chafed spot also. My neighbor's brand X mower had the clutch wire chafing against the frame.
Jerry (KS)
05-07-2007 17:36:12
Reset the airgap on the PTO clutch. Probably just a little too great.
Bob
05-07-2007 19:17:50
 Re: John Deere Model 317 tractor in reply to Jerry (KS), 05-07-2007 17:36:12
The airgap only affect initial engagement.
Closing the airgap oves the plates closer together, so the magnet can pull them together. It is set by tightening the blade brake. But onece the clutch pulls in, it should stay pulled in.
It sounds more like a partially-shorted magnetic clutch coil that is drawing too much current, and tripping the breaker. If possible, measure the clutch's current draw... IIRC, in the 3 to 4 Amp range, more than that will cause problems
