70d standard plow size
stn.tn.
05-07-2007 11:41:57
I have a newly overhauled 70d and was considering plowing some with it at plow days and etc..,was curious if it would handle 4-14,trl type plow ok or should i just use 3-14`s.
WeirdDeere
05-07-2007 23:43:16
 Re: 70d standard plow size in reply to stn.tn., 05-07-2007 11:41:57
I can't speak for a trailer plow, but I tried plowing with my 70D rowcrop and a three point 4x14. This is in Ohio clay, and it was still slightly wet.
third party image
Couldn't pull it. Didn't have enough traction! Power was not an issue in 2nd gear, but it would NOT keep traction on the land wheel. I had gotten rid of the calcium in the rear tires, I had hoped I might get lucky, but no go. Now I need to find some cast weights for a decent price.
Brandon
grantl
05-07-2007 16:59:33
It's plow day for fun,don't go out and hurt your tractor or be embarrased, you know it will handle 3-14 with ease.Go have fun
JLG
05-07-2007 14:12:08
Some places pull harder and some easier, but I would think a fresh 70 Diesel would be able to pull 3-16"s just about anywhere and 4-14's most places. I have an overhauled G that I'm told should be around 50 hp, and I can pull 3 - 16" in 2nd anywhere around here (about 3 1/2 mph and that seems to be about right for my plow). I think the 55's and 555's are the right era for the 2-cylinders. Then in the early 1960's they were called F610, F620, or F630. Parts are easy to find for the later ones, I dont know how they are for the 55's. Any of them can be found 3 or 4 bottoms and hydraulic or rope lift.
stn.tn.
05-07-2007 16:48:39
 Re: 70d standard plow size in reply to JLG, 05-07-2007 14:12:08
thanks you`all! i appreciate all the info, a friend of mine has 3/16s i think i will try first, was down at his house a little while ago and planning to borrow them tomorrow and see how she does in this east TN. clay with them.this also should be good on a fresh build too i would think. thanks again
stn.tn.
05-08-2007 10:36:22
 Re: 70d standard plow size in reply to stn.tn., 05-07-2007 16:48:39
thanks all, just came home for lunch ,been plowing this a.m.,. I had a ball!!, BEEN QUITE A FEW YEARS,pulled 3/16S fair considering how hard the ground wasand they were rusty finally got them to shed. A friend brought his 3/14s over it pulled 3/14s great, had a ball,even got the new clutch adjusted where it needs to be. Seems like the way she pulls I could pull 4/14s in some sandy bottom soil, wished i had pictures!!! thanks everyone!!!!
buckeye al
05-07-2007 14:03:30
It all depends on soil types but from what I contend with here in Ohio tells me Buickanddeere is right. The 70D had a high speed transmission! I pull a 3-14, 555H with mine and in tough clay or dry hard ground it's a 2nd gear pull. In average clay loam it's a 3rd gear pull most all day up hill & down, no sweat. Decent amount of guts in reserve for most tough spots. With 4 bottoms you'd always be in the 1st, 2nd range!
I can't prove it with actual tests but my gut tells me to get to a "ready to plant" seedbed, acres per hour and fuel costs per acre would be higher with the 4 bottom than with three. There will be more slippage plowing & probably one more pass fitting if pulling the 4.
Though with lighter soils or going down hill the 70D will pull the 3-14 @ 7" depth in 4th, that's too blamed fast! Entry and exits become long and slow. Turned soil is thrown past the leading bottom's cut and with power steering I can't turn it quickly enough on the ends. Maybe you can but I can't!
buickanddeere
05-07-2007 11:48:18
4x14 is too much in heavy clay.
stn.tn.
05-07-2007 13:02:47
 Re: 70d standard plow size in reply to buickanddeere, 05-07-2007 11:48:18
thanks ,wasn`t sure but thought i would ask,3x14`swould be the all round bet for me then,would you say maybe a model 55 or so?? open for suggestions on what would be the best plow to purchase.
