1938? John Deere combine
Floyd Green
05-07-2007 10:13:57
I have two gas engines out of scrapped 1938(I think) John Deere 36A combines. The engines are 4 cyl. Caterpillar. Apparently Cat engines were used by JD for a couple of years. Both radiators are good and the engines are mostly there but It would take both too make one good engine I suspect as each has a few problems. Engines will not turn over with hand cranks but I have not pushed to hard as I do not want to break a hand crank. There are some extra parts (piston rings in boxes etc.)that would be included. I do not need these engines as I collect mostly CAT tractors. By the way, there are boxes of antique wooden bearings (JD green)that were for the combines.This stuff is for sale or trade.
Glen in TX
05-07-2007 12:06:47
 Re: 1938? John Deere combine in reply to Floyd Green, 05-07-2007 10:13:57
Best and Holt combine lines from as far back as 1880 were merged into Caterpillar combine line in mid 1920s. In 1936 John Deere aquired the Caterpillar combine line which consisted of model Nos. 34, 36, & 38 that had been built at Caterpillars Peoria plant. JD replaced the 34 & 38 with their own models 33 and 35. JD continued to build the 36 for the Pacific hillside market till 1951. That's why they had CAT engines and I don't have other info on how long the CAT engines were used on the 36 thru entire production or what.
Floyd Green
05-07-2007 12:22:42
 Re: 1938? John Deere combine in reply to Glen in TX, 05-07-2007 12:06:47
As I understand it, these engines were used for two years only and only on the JD 36A combine. Also, As I understand it, there were fewer than 500 of these engines made for this usage. I was looking through the 36A owners/operators manuels and I found the CAT engine info but they were not listed as CAT engines. I only knew they were CAT as I was researching CAT part numbers at the time and recognized the part numbers as CAT #s.I just remembered that the original 36A wheels are still laying in the field where I got the engines.
Glen in TX
05-07-2007 16:44:03
 Re: 1938? John Deere combine in reply to Floyd Green, 05-07-2007 12:22:42
That's interesting Floyd. I don't have any other info on the Cat, Holt or Best combines before that except seeing it mentioned in Grain Harvesters book that Holt began putting gas engines in their hillside combines about 1904 claiming it as the first successful gas engine powered combine.
