D pto
PeterE
05-07-2007 09:46:41
I just bought my first D, a 1940 hand start. Mine does not have a PTO, but I believe it was an option at the time. I see the flat plate on the operator"s platform.
How hard is it to add a PTO? Is it just a shaft that connected behind that plate, or is there more work to it?
I"m just curious right now about whether I should completely forget about trying to add a PTO, or if it is a possibility.
Patrick Mosset
05-07-2007 18:13:31
 Re: D pto in reply to PeterE, 05-07-2007 09:46:41
I have a few Ds here that I am parting out and they have the ptos in them,Let me know if you are still looking for one and i will have to see about weight to have them shipped,thanks patrick ,my email is [email protected]
Glen in TX
05-07-2007 11:53:32
If you want a PTO you better be scrounging scrap yards soon with high scrap prices looming! You need the guts (gear case) that fit into LH side along with the lever and shifter fork plus the shaft that slides in from the back. If you see a large cast piece on side with a plug on it instead of a flat sheet metal cover on LH side of trans you already have the gear case yet still may need the shifter fork and shaft to slide in. Sometimes you find them that way with gear case but not the rest of it. Same PTO parts fit all 1931-53 D so they aren't that hard to find.
third party image
third party image
720 in pa
05-07-2007 11:39:16
it is possible to install a pto.i also have a 35 handstart d.i do not have apto on mine altho ive thought about it.probably the worst part will be finding one
