4250 Oil Pump
Walter Squires
05-07-2007 07:41:35
A friend of mine is doing an underhaul (rod & main bearings) on his 4250 which has also been experiencing low oil pressure when he went to the JD dealer to order a "new" oil pump they told him that only a remanufactured was available, does this sound right considering a 4250 isn't that old.
G/MAN
05-07-2007 08:10:08
 Re: 4250 Oil Pump in reply to Walter Squires, 05-07-2007 07:41:35
What's the definition of "low" oil pressure? It should run in the 45-50 psi range at high-idle with hot oil using a known good mechanical gauge. The in-dash gauge really doesn't tell you much. It's rare to see a major issue with an oil-pump, at least the crank-driven ones that aren't subject to gear failure. If it doesn't show major wear or scoring inside, it's probably not the problem, if the oil pressure really is "low". There are also o-rings on the pressure tubes that should be checked and replaced, and the valve assembly that actually controls pressure too.
Walter Squires
05-07-2007 12:02:07
 Re: 4250 Oil Pump in reply to G/MAN, 05-07-2007 08:10:08
He said he was ok at high idle about 50 psi, it was at low idle that it droped to 12 psi and the warning buzzer would go off.
Walter Squires
05-07-2007 08:35:58
Hey G/MAN I'll give him a call later today and find out what the pressure readings are, I do know he put a mechincal gauge on it for the readings.
Mike M
05-07-2007 07:52:19
Wouldn't suprise me ? If you buy a brand new GM car (maybe other brands as well)and the tranny goes out the next day you are going to get a reman unit as that's all they list.
