4840 won't start with key
Howard H.
05-07-2007 07:28:04
Saturday the old 4840 wouldn't start with the key - it still starts very easy by shorting across the starter.
Where is the gear shift park sense switch on a 4840? In the cab or down near the trannie?? Is that the most likely culprit??
Thanks for any advice,
Howard
Bob
05-07-2007 07:46:40
 Re: 4840 won't start with key in reply to Howard H., 05-07-2007 07:28:04
PLEASE be CAREFUL when troublehooting this, so you don't get run over!
G-Man posted about the powershift version.
If Quad Range, the neutral start switch is also on the side of the transmission case, near the shift levers.
G/MAN
05-07-2007 08:11:14
 Re: 4840 won't start with key in reply to Bob, 05-07-2007 07:46:40
All 4840s are powershift - QR wasn't an option. At least here in the states - they might have built 4840 QRs for export.
Bob
05-07-2007 08:28:57
 Re: 4840 won't start with key in reply to G/MAN, 05-07-2007 08:11:14
Sorry about that!
I looked at "4840", and read "4640", probably 'cause I'm OH'ing one at the moment!
G/MAN
05-07-2007 07:31:40
On the transmission control valve on the RH side of the transmission case. It could be that or a faulty start relay.
Howard H.
05-07-2007 07:52:40
 Re: 4840 won't start with key in reply to G/MAN, 05-07-2007 07:31:40
Thanks, guys... Where is the starter relay you mention??
I know to be careful - I bought a tractor a while back at an estate sale - and didn't find out until I went back to load it that the reason for the sale was the owner tried starting a tractor from the ground and it ran over him.
HH
Bob
05-07-2007 08:11:30
 Re: 4840 won't start with key in reply to Howard H., 05-07-2007 07:52:40
30-series starter relays are at the front LEFT of the firewall, under the hood. IIRC, the 40-series have the relay there, too.
