720: \\\\Maybe a design that allows for 2 of the paddles to be removable would allow it to be used for say a JD H or IH C up to a JD 80-830 or IH 650.\\\ How about some type of sliding panel arrangement so that you could adjust the panel surface area depending on the power input. (big panel=high hp tractor, small panel= small tractor). Just slide the panels out a few inches at a time using stop pins. Ideal would be a governor operated slat affair wo that the fan rpm would add panel surface area as it attained overspeed, and trim it back at underspeed. Also, I've been doing some research on the Prony Brake type of dynamometer. I'm wondering if these might actually be a bit easier to build. I looked at the rearend of my VAC Case tractor today, and pondered this design: Take a junk VAC, transmission on back, strip the tires from the rims. Build two wooden block strap brakes for the rims. These would be tied together through a linkage, and then to a scale if torque readings are desired. The differential would make certain the brakes were loaded equally (the lighter turning wheel would try to turn faster, drag harder and slow until it "equalled" the load of the other wheel). Two plastic tanks, like tire leak testing tanks, would be provided under each wheel, and would allow the rim to dip about 15-20% into the weater bath for cooling. Now you input the power through the transmission driven powershaft at the rear. You could shift the transmission through any of the four gears to provide ranges of load if required. The direction would be reversed because of the pto rotation, but that shouldn't matter, as the gears will still lube. Now, I'm curious if the rims will stay on the five point mounts of the wheel/rim connection? There should only be the same perimeter loading equivalent to about double or triple of the nromal tractor pulling in the field as you shift it into higher gears for more powerful tractors, and I think the rear-end could stand that. Now help me out guys, am I missing something here? Of course, just about any tranny driven pto/rearend would do (Massey, WD-45, etc). This is the direction I'm heading at the moment. Anxious for input. Frank
