2640 oil in water
Dieseldaawg
05-06-2007 19:44:40
Working on a well used 2640, found motor oil in the antifreeze. Whats the most likely cause, heat exchanger? motor runs good and not blowing any coolant, if it was a cracked head i would expect to see some overflow. Also had diesel in the motor oil, bad cup seals on the injector pump drive shaft i hope. Any help appreciated. Jake
bighead
05-06-2007 20:34:41
 Re: 2640 oil in water in reply to Dieseldaawg, 05-06-2007 19:44:40
Don't remember for sure if that engine has an oil cooler (other versions of that engine did... don't remember for sure about that one). If it has an oil cooler, then that's your best bet. I've seen oil in the antifreeze caused a couple other ways... but 95% of the time, it's the oil cooler. A shop should be able to test it.
msb
05-06-2007 20:01:13
 Sounds like a whole herd of trouble. in reply to Dieseldaawg, 05-06-2007 19:44:40
Most likely pump seals causing the fuel dilution, but could be the small fuel pump--commonly called a lift pump at this site.You might take it off first and see if the tell, tail traces of engine oil has been washed off the inside of the "lift" pump. And since the oil pressure is greater than the radiator pressure, looks like the oil cooler is in need of some remedial attention. Could just be a gasket needing replaced.
