4020 Rockshaft Housing Install
MRN
05-06-2007 18:56:18
The I&T manual says to make sure that the "cam follower roller in valve housing is positioned to the rear of the follower arm in the transmission housing" My question is how do I do this? I don't even know what the cam follower roller in the valve housing is, please help.
Thanks
msb
05-06-2007 19:48:00
 Re: 4020 Rockshaft Housing Install in reply to MRN, 05-06-2007 18:56:18
If you look down inside the housing you will see a large C shaped piece of steel that comes from the bottom to almost to the top of the case. On top of that is a pecular shaped steel cam follower about 4" tall and about 1/4" in width. It is attached to the C with an adjusting bolt with a castle nut towards the rear of the tractor. This piece must be standing up so it will engage the cam on the rockshaft itself.It will protrude above the top of the traansmission case. This "pecular "cam follower can get knocked forward, will fall down and won't engage the cam. Should that happen, its a lick over and the rockshaft housing has to be lifted off all over again. Just be careful to not knock the follower forward and you will have it licked the first time. Its not really that hard to do if you use a cherry picker to lower the housing down in place. Pay particular attention to that castle nut and the roll pin in one of the castle slots as you will probably have to adjust it later. Then you will have a better idea about how to adjust the sensitivity of the 3 point hitch.
G/MAN
05-06-2007 19:09:00
It's kind of hard to explain in writing, and I'm sure that the I&T manual isn't giving you a good picture, so you might want to just get the pages out of a real JD service manual, because they have more and better pictures and illustrations that will make it much easier to understand. Maybe someone one here can email you some pics, because you want to get this right, otherwise the hitch won't function correctly and you'll have to pull the rockshaft valve off the rockshaft housing to fix it.
