2840 Hi Range Stuck ???
tractortom64
05-06-2007 11:54:03
Plowing today with a 2840. Shifted into hi range and it acted like it was stuck in two gears at the same time. Engine labors down and would stall if i didn"t put the clutch in. Low range seems fine but that"s all I have now.
tractortom64
05-06-2007 14:57:13
 Re: 2840 Hi Range Stuck ??? in reply to tractortom64, 05-06-2007 11:54:03
Oh Well - Thanks Gman,
G/MAN
05-06-2007 12:11:47
I hate to tell you this, but I worked on one of those several months ago, and it wasn't pretty. I can't remember the exact cause of the failure at the moment, but the end result was that the two-speed internals ended up welded together. I think there was some sort of oil supply problem to the clutch packs, and that if it hadn't welded together, it wouldn't have worked at all because neither side was engaged. And if I'm not mistaken, it was stuck in low also. I can go back and check if you like, and post back with the cause and a more accurate description, because your situations sounds about identical.
tractortom64
05-06-2007 13:29:25
 Re: 2840 Hi Range Stuck ??? in reply to G/MAN, 05-06-2007 12:11:47
Gman I would appreciate it if yiou could check sounds like the same thing.
G/MAN
05-06-2007 13:53:34
 Re: 2840 Hi Range Stuck ??? in reply to tractortom64, 05-06-2007 13:29:25
I don't think what I found will apply in your case. Went back and looked and the failure was due to improper assembly when someone had been into the tractor previously. A sleeve was improperly installed and was dumping the lube pressure, which cause the clutch pack to fail. The first thing to do in your case would be to start with system pressure and lube pressure checks in both high and low range to see if you're dumping a bunch of pressure. From there the next check would be at the shift valve and valvebody themselves if you find that there's a problem. It might also be possible to use air-pressure in the test ports to pressurize the clutch packs and listen for internal leaks, etc. The fact that it acted like it was stuck in two gears or bogging down doesn't sound good. It could be a broken sealing ring, a crack in the valve or other problem that was allowing oil to both sides of the clutch at once, or possibly a mechanical problem further back in the transmission where the clutch pack shafts send their power. Only time and diagnosis will tell.
