5020 Puller
Big Motha Green
05-06-2007 08:58:02
How"s everybody doin? This summer me and my nephew were planning on pulling our 5020 in the farm stock class, it has a 619 in it. My question was is it hard to turn the pump up without having to do major modification"s? It also needs a clutch, can a stock clutch holdup fine to the sled or is there some modified version that I need to look into. Any advice on tire pressure, duals or singles, weight placement(weights behind seat or in front of back tire) would be appreciated.
buickanddeere
05-06-2007 20:03:58
 Re: 5020 Puller in reply to Big Motha Green, 05-06-2007 08:58:02
Install a pyrometer in the manifold ahead of the turbo. If it gets too hot, back off on the fuel or intercool better. Farm stock? Is this 619 natural aspirated or is your 5020 legal with a turbo?
Big Motha Green
05-07-2007 04:17:00
 Re: 5020 Puller in reply to buickanddeere, 05-06-2007 20:03:58
The 619 is turbocharged and intercooled, just your normal setup. The tractor is legal with a turbo. Last summer I talked to the guy in charge of the tractor pull, I said "Hey man, I've got a 5020 with a 619 in it, will that cause any problems?", he was loading his tractor with weights to get in the 21,000 lb. class, and he was in a hurry, so he blurt's out, "That guy down there's got a 619 in his tractor!(like, what's the big deal)" So I thought to myself, there's your answer. They'll only be a problem with my tractor if I'm in the #1 spot. Thank's guy's
Big Motha Green
05-07-2007 13:30:38
 Re: 5020 Puller in reply to Big Motha Green, 05-07-2007 04:17:00
Traction really shouldn't be a problem, I'm going to put 20.8-38's on the inside, there Co-op radials, I swear there as big as some manufacturer's 20.8-42's, there big 20.8's. The duals will be 18.4-42's, I think that should get me buy.
buickanddeere
05-07-2007 08:54:05
Might want to stick a set of 6030 decals on it. All the HP in the world isn't going to win a pull unless you look after the three most important factors. They are traction, traction and traction.
G/MAN
05-06-2007 16:33:03
If it has a Bosch inline pump on it, they're relatively easy to turn up. The plate on the bottom rear of the governor housing with 4 screws in it needs to come off, and underneath you'll find a set-screw that should be around 12mm jammed on a headless screw with a flat screwdriver slot in it. Turning the center screw in increases fuel delivery, turning it out decreases fuel delivery. I don't know about your 6619, but on some 400-series Deere engines with Bosch pumps, you have to pull the oil-filter base off to be able to get the plate off and get in there for the adjustment, as the back of the governor housing is very close to the filter base. It might be possible to get in there and do it with the base on with a lot of finagling, but it's usually quicker and easier to pull the base.
msb
05-06-2007 19:52:17
 Re: 5020 Puller in reply to G/MAN, 05-06-2007 16:33:03
Think its a 10 mmm lock nut.
G/MAN
05-07-2007 07:35:00
 Re: 5020 Puller in reply to msb, 05-06-2007 19:52:17
It may be different on that particular pump, but every Bosch "P" pump I've ever "tweaked" has had a 12-mm lock nut. The screws that hold the cover on have 10mm threads, though.
