water in 4020 POWERSHIFT
J heitkemper
05-06-2007 06:14:40
After close inspection. The filler cap was plugged and would not allow venting of moisture , After I drain out present oil,, Will 2 gallon kerosene or diesel fuel be ok to flush out the tranny case, Before I add New oil .. I fear that it may be harmful to seals , bearings and Clutch Pack ,, Your suggestions are very much appreciated ,, Thanx Jim
J heitkemper
05-06-2007 20:11:03
 Re: water in 4020 POWERSHIFT in reply to J heitkemper , 05-06-2007 06:14:40
Thanx Guys ,. Will use your advice . I always change oil when the pressure has troble holding at 2200 rpm ,,,. The oil is always milky , Changed Brake seals , is nearly always inside , rarely has been rained on ..,I usually have to change fluid twice a year and probably put about 200 hours per year on Her ,A Lot of oil has been put through this Lady , Thanx , Jim
K.B.-826
05-06-2007 12:24:18
Like the other guys said, if it were mine, I'd fill it up with new oil, get it good and hot, then change the oil and filters again. A significant amount of oil remains trapped in the hyd. oil cooler and the main pump. You can pump this oil back to the reservior so it can be drained. To do so, get yourself a piece of hyd. hose with a male coupler on one end, and nothing on the other end. Plug it into your remote coupler and stick the other end down the fill tube. Tie the hose in place, or it may jump out and give you an oil bath. 20 series powershifts had that engine disconnect clutch lever on the left side of the dash. Pull the lever back, this stops the transmsission from turning, and the transmission pump will not turn as well, thereby not supplying any more oil to the main pump. Start the engine and pull your SCV lever to flow oil through the hose you stuck down the fill tube. When you hear the main pump starve for oil, shut down the engine and drain the hyd. oil.
G/MAN
05-06-2007 10:36:05
msb is right. It's probably not worth the trouble to try to flush the system with diesel fuel or kerosene. Flushing wouldn't really hurt any interior components, but it may not get the water out, either. I'd remove the drain plug, the sump screen, etc and let it drip. Change the filters, put in new oil, run it for a while and then let it sit overnight. If you worried about any remaining water, carefully back out the drain plug and see if you get some water out before oil.
msb
05-06-2007 10:23:10
Kero won't hurt, but oil still floats on water, so you probably won't get all the water even if you flush the transmission.If you use the kero, follow that with an equal amount of hydraulic oil as a flush.Depending on how much water you found(if significant-a gallon or two), I would fill the transmission,work the tractor hard for a day and then drain the transmission while the oil was still hot and refill it once again with new oil.Don't forget to change the two transmission filters both times.Been a while and I have slept many times since, but the powershift has two drain plugs doesn't it?
