2130 hydraulic
daryl kennedy
05-06-2007 05:01:25
he gents
hydraulics wont lift after about 5 minutes of tractor running
no power steering either
works okay upon start up
no oil in reservoir
changed filter in tranny and screen replaced the oil as well
any ideas ?
Tech7
05-06-2007 18:26:34
 Re: 2130 hydraulic in reply to daryl kennedy, 05-06-2007 05:01:25
sounds like you have a high pressure leak. Upon start up,remove the hyd oil filler cap and look/listen for sraying dripping or an oil fog ahead and slightly to the right of the filler cap hole. This is the most common place for these units to have troubles. If this is the area of the leak you will need to remove the rockshaft housing to repair the leaking valve. Deere sells everything you need,gasket,o-rings etc as a kit. Hope this helps, Bob
