JD 4650 Over Heating Problem
JJ Farms
05-05-2007 14:51:54
My 4650 will run cool and just out of the blue will jump all the way to red. I put new thermostats in it and found a crack in the water pump impellers. Replaced water pump run fine went to the feild with a para plow did great then turned on the end and went over the hot. Anyone had this problem before?
G/MAN
05-06-2007 10:42:44
 Re: JD 4650 Over Heating Problem in reply to JJ Farms, 05-05-2007 14:51:54
It could easily be the fan clutch, and that's what I'd suspect first. The will get hot in pretty short order if the clutch doesn't lock in, because a failed clutch usually tends to get looser and looser the hotter it gets, and actually slows down as it needs to be speeding up. When working properly, it will kick in and out as needed to maintain temp. Using the fan clutch was a good idea as it saves horsepower and improves average fuel economy, but a farm tractor engine is a harsh environment for those clutches and the first ones didn't hold up that well. They've since been improved quite a bit, but we still see them fail periodically on newer tractors Deere makes a "lockout" kit for the clutch to make the fan-drive solid, as the new clutchs are pretty pricey. I'd drop a couple of bucks on one of those before tearing into the electrical system, sensor, gauge etc. although the problem could be there, too. If you lock the clutch and the cooling problem goes away, you're done and can decide whether to leave it locked out or drop some bucks on a new clutch. If that doesn't fix it, you can start diagnosing the temp gauge circuit. If you don't want to make a parts run, operate the tractor in the field until it gets hot on you, then get out and see how much air the clutch is moving. If the fan is roaring pretty loudly and moving a lot of air, the clutch is no good.
donmyeil
05-06-2007 05:25:15
The sending unit on these is notorius for giving false readings. Its located on the thermostat hsng.
bighead
05-05-2007 22:04:59
+1 on the bad gauge suggestion. I've run into lots of bad gauges on these. I'd suggest that you tap on the gauge with a screwdriver handle... if it jumps around, then you have either a bad gauge or a bad connection. Also check the sender unit wire under the hood and make sure it isn't grounding out on something.
If you're reasonably sure that it IS running hot, one thing to check is your pulleys. With years of running in the dirt, the grooves will wear out... and even a good belt will slip in them. Also check for lots of crud in the radiator fins, oil cooler fins, or packed between the two. Make sure coolant is full and isn't getting combustion pressure into it.
960
05-05-2007 19:25:41
Concur with a previous post if it is erradic it is most likely the gauge.
matthies
05-05-2007 18:54:12
I've seen the fan clutch cause problems also. Deere has straps to lock the fan directly to the clutch for heating problems. chris
Shoes
05-05-2007 18:32:44
This is not meant to be an insult, but is it actually running hot, or is the gauge possibly not working correctly. If you have access to an infrared heat gun, I would check the actual temperature of the engine block, when it shows hot on the gauge. You may not have a mechanical problem with the engine or the cooling system, and might just find an electrical problem with your gauge, sender. or wiring. Good luck.
Mike w J
05-05-2007 15:56:29
My brother has a 4650 on our 16row planter when pulling hard and it starts to warm up past 1/2 way on the gauge I noticed amp meter would drop . The belts are tight but sometime he must have let them run loose and wore out the altinator pully . When the fan clutch kicks in the belts slip could that be your problem ?
