3020 no reverse
stuart
10-30-2003 15:42:09
I have a 3020 diesel sn 76,960 (I believe a 66 model)that buzzes when I put it in either reverse. I have checked the linkage and even taken the floor plate off to make sure that everything is engaging properly. When I try to engage it from the side shaft it still buzzes and tries to move a little. Would anyone out there think I would be correct to say that the synchronizers are worn. I will probably have to split the tractor myself to fix it. What other parts should I look at and replace. Also does the seat and rocker arm need to be removed. Would I only replace the reverse synchronizers or the forward as well.
Thnks, Stuart
Central Texas
stuart
11-02-2003 07:07:14
 Re: 3020 no reverse in reply to stuart, 10-30-2003 15:42:09
where do I split the tractor at? between the bell housing and the transmission. Or at the bell housing like I was changing the clutch. I have some 6x6x1/4 angle to build a stand and bolt to the side of the frame and will probably put some large bolts at the bottom so I can adjust it up and down. I guess just using a floor jack for the rear would be okay.
andy
10-31-2003 18:24:02
Stuart, you never said if it is a power shift or a syncro range there is a big difference, hope i can help, Andy
stuart
11-01-2003 01:39:58
 Re: Re: 3020 no reverse in reply to andy, 10-31-2003 18:24:02
I assume that it is a syncro-range. It has 2 reverse and 8 forward gears. The top center shaft has small thin metals plates enclosed in a cast housing that slide forward when then shifter is pulled into reverse. The exploded version of the top shaft shows to have one synchronizer with plates enclosed in a drum housing.
37D
10-31-2003 04:48:37
The only place I know of to obtian these parts new is "mother deere" & this won't be inexenpsive, youll probably need all the sycronizer packs, plus, very likely both shifters, & possibly the shifting cams. When I did my 7520, I took the top shaft to my local JD dealer, as he has all the special tools required to dis & reassmble it. When I left with the repaired upper shaft, I was carrying $1400 in my hands! They did replace the reverse gear, (a 7520 dosen't have a syncro rev)at,I think $232, I also had to buy the hi-lo shifter at over $200. All told I got about $2000 in parts including the $100 labor to overhaul the top shaft, & did all the major work myself. I'd think a 3020 might be a little less, but it's still going to take a bunch to fix it right, & you don't want to do it more than once!
david val
10-30-2003 23:40:43
you need to remove the top shaft (transmission drive shaft). for that you have to split tractor at transmission and remove rockshaft. better get a manual that will guide you through the work.
when the shaft is removed and disassembled you can check condition of individual parts and replace as nessessary.
david
STUART
10-31-2003 01:49:17
 Re: Re: 3020 no reverse in reply to david val, 10-30-2003 23:40:43
where would be the best place to look for these parts at a good price?
Jim
11-01-2003 10:14:24
 Re: Re: Re: 3020 no reverse in reply to STUART, 10-31-2003 01:49:17
John Deere is the only place for the parts that I know of, all together it cost me about $600 to rebuild my 3010, it had the same symptoms. Try adjusting the linkages first. If you take off the top cover on the trans, you can see the 3 clutch packs (JD calls them syncro disks) Mine were worn out, they are very thin even when new. The fiber coated disks were worn clean, after installing the new disks and replaceing one of the disk hubs and matching gear, it works fine.
Jim
