G/MAN
05-05-2007 12:54:07
Re: JD 4000 HYDRAULIC PUMP in reply to RJ IN WYO, 05-04-2007 20:21:03
It could be any number of things, from input shaft seals that failed entirely to a piston plug seal to blown o-rings on a pressure line fitting to the pressure line itself near where it connects to the pump. If you've got serious leakage as you described and it happened with a big load, it's probably high-pressure oil, meaning a piston plug seal, pressure line or other part exposed to system pressure. Be VERY careful if you go looking for the leak, as high-pressure hydraulic oil can easily penetrate the skin and injection injuries are very nasty - gangrene, blood poisoning, loss of extremities and even death if not properly and quickly treated. I'd clean the pump area as well as possible with compressed air or a power-washer, start the tractor and let it run for a second or two, then shut it off and see if you can trail the leak back to its source. As far as fixing it yourself, that's probably an option if you want to try it. That pump is relatively simple, but certain things must be done and done right if you want it to live. You'll need a manual, some special tools - torque-wrench, dial indicator, a press to remove and replace the bearing cones, the JD special tools for removing and replacing the check valve seats if they're damaged (and they likely are on an old pump like that) and for installing the outer pump shaft seal without risking damage to it, a good clean work area, a method of washing parts (a pan full of gasoline isn't recommended), etc. If you're going to do it, do it right - replace the inlet and outlet check-valves, shaft bearings, piston plugs, all of the o-rings including going through the control valve block, consider replacing the piston springs, pistons, the bearing race the pistons seat against, the needle bearings the race rides on and the side washers if nessary. If you don't want to go to the time and trouble to rebuild it right, you're better off to simply bolt in a new or rebuilt unit. It'll never be right if the check-valves are shot, the valves seats are all hammered and won't seal to the disks, etc. It's usually just about as cheap in terms of time and labor to simply replace the shaft, the bearning cups and cones, race and rollers and washers all at once and simply assemble the new parts rather than disassembling the old shaft to reuse it, especially if it shows a lot of wear where the two seals ride on the input end. We will on occasion rebuild a main pump if it hasn't catastrophically failed, shows acceptable wear, etc and if there isn't a constant and large demand on the tractor hydraulics, such as a yard tractor, light field-work tractor, etc. If it's a loader tractor or field tractor that's running orbit motors, using all of the SCVs most of the time or otherwise is really working the hydraulic pump all the time, we normally recommend a new pump. The fact is that they can and will wear out eventually, and they can crack as was mentioned. If a crack is missed and you go to the trouble and expense of properly rebuilding and reinstalling the existing pump only to have it fail again in 5 hour or 500 hours, you haven't saved a dime over the cost of a brand-new pump that will be covered by a parts warranty, and in fact you'll have wasted several hundred dollars on new parts to fill a junk pump and will be buying them all over again when you replace the pump as an assembly. Even a rebuilt pump with a decent warranty is usually a better option than taking a chance on rebuilding a questionable one. Normal and the most convenient removal procedure on your 4000 would be to remove the front axle and drop the pump out the bottom of the frame. 2 or 3 hours was mentioned as a repair time, but I'd consider that to be pretty optimistic for a thorough inspection, clean-up and rebuild. The bearing cups have to be removed from the housings, the new bearings installed with the old shims to start with, the housing torqued to specs, endplay checked, the housing disassembled again, shims added or removed as needed, reassemble and retorque etc etc etc until the endplay is in specs. Removing the check valve seats can be a bit of a challenge and care needs to be taken not to damage the bores they are located in, etc. I don't do many of those pumps and am not and don't try to be a speed-demon when rebuilding one, but I'd say 4 hours is going to be closer to what it will take from the time you get it out, blast the thing off with the power-washer, throw it on the bench and tear into it. An extra half-hour or hour during assembly double-checking everything and being patient sure beats removing the pump again if it doesn't function right when reinstalled. If you've never done one, it will take as long as it takes. From an economic standpoint, it's actually pretty hard to justify rebuilding those pumps these days, what with the costs of labor and parts, especially if the hyraulics are used hard and often as I mentioned. In that case, it's a no-brainer - install a new one. If the shaft needs to be replaced and you go with all new parts there, you're going to have around $300 in the shaft assembly and bearings alone. Add in a seal kit, new piston plugs, check valves and seats, a new stroke-control valve for the valve block - don't even think about reusing the old one if you've got the block apart - more than likely you'll end up replacing it later anyway, etc and you'll easily be in the $500 range for parts. Figure 3-4 hours of labor at a minimum of $50 per hour, tax and other miscellaneous expenses, and you're going to have most of $800 in it easily, and when it's all said and done you can probably figure on $1000 even or thereabouts to have it properly rebuilt at a Deere dealership or even a quality independent shop. And you'll still have and old housing with old pistons in it, and that's where all the real work is done. A new 3 cu.-in. pump from Deere will set you back somewhere around $1700. You can upgrade to the bigger 4 cu.-in. pump, gain yourself some capacity and have a pump that won't have to work as hard for a given job for about $1860. That's a lot of money, but rebuilt ones aren't tremendously cheaper, and there again, regardless of their inspection and rebuild procedures, you're still dealing with a used housing with untold hours on it that could decide to crack at any time. The supplier will probably replace the pump, but probably won't cover removal and installation labor. The other thing you'll have to do regardless of which route you go is heat the hydraulic oil to operating temp after the pump is installed, and check and adjust standby pressure. If you don't, the pressure could be too low and you'll lose lift capacity, or it could be too high and cause other components to fail and leak. And of course a new sump screen, filter and hydraulic oil would be highly recommended, and you'll likely end up replacing the pump drive coupler, bleed lines, etc.
