4430 t rans
pat terlesky
05-04-2007 19:26:48
I have a john deere 4430, it does not want to stay in 1st or 2nd. it`s a quad shift trans, so when I try to shift into 1st or 2nd it will not go , as I let the clutch out it jumps out or slips out . Thought maybe it`s an adjustment. tractor has low hours and easy use, I`m greatful for any help.
bighead
05-05-2007 21:58:53
 Re: 4430 t rans in reply to pat terlesky, 05-04-2007 19:26:48
Yep, sounds like a linkage adjustment problem. Hopefully you haven't done damage yet. Adjust the shifter rods so that the gear shift positions line up with the detents.
msb
05-04-2007 20:00:45
Cab mount biscuits have probably settled. You can replace them and that will most likely fix your problem or you can adjust the shift linkage to compensate for the sagging.
