420T J.D.
Lyndal
05-04-2007 09:48:26
I am trying to find the year this tractor was made. It is a J.D.420T the serial number is 105458. Would appreciate hearing from someone who knows
jturbo10
05-04-2007 11:20:33
 Re: 420T J.D. in reply to Lyndal, 05-04-2007 09:48:26
I have an identical 1957 John Deere 420T. As you indicated it is classic green with yellow trim and straight steering wheel. My tractor has 12.4x28 tires on rear. Great little tractor with DTM 3 point and plenty of power for bush hogs, drag blades, etc. Mine is getting ready to go into the hangar for an engine overhaul and hydraulic lift arm machining to cure the chronic leaking problem common to this tractor.
Wayne in Tn.
05-04-2007 11:09:49
Yep, you have the 1957 model. Here is more information than you probably wanted.
The 420 was built in three phases for 3 years: 1956-Phase 1 Identified by all green color.
1957-Phase 2 Identified by yellow stripe on hood and nose piece. Straight steering wheel.
1958-Phase 3 Identified by yellow stripes and slant steering wheel.
donwisc
05-04-2007 10:08:50
This serial no. shows to bew built in 1957. You can check this yourself by looking on the left under research and info, click on serial numbers and you can look up most any old tractor.
