870 case tachometer
jddeere
05-03-2007 19:47:55
still fixing some small things on this tractor. tach cable isnt broken and fits down good into the motor. what will cause it to not work. the gauge works if you spin it by hand.
720 in pa
05-04-2007 03:22:23
 Re: 870 case tachometer in reply to jddeere, 05-03-2007 19:47:55
first take the tach cable and unscrew on engine side.start engine look down tach drive hole.if it turns in there reconnect cable.if it dont turn the drive is bad.also do the same on tach cable end,start engine to see if cable turns
