GT275 stops running when hot
Curt Coenen
05-02-2007 18:22:47
I checked the spark plug, there is spark, so does that eliminate the ignition coil? Where do I go from here?
8850dave
05-03-2007 04:14:42
 Re: GT275 stops running when hot in reply to Curt Coenen, 05-02-2007 18:22:47
I had same problem last year, would run 1 hour then die unless I pushed choke on. I am going to install new fuel lines and possibly the fuel pickup in the tank. I changed the coil and fuel pump last year as well as took carb apart and cleaned.
