JD 435 diesel
Peter Campellon
05-02-2007 16:23:05
Hi Guys, I am wondering if anyone knows how much crankcase oil to use in a John deere 435 detroit diesel. The IT manual says 9 Quarts, however the oilpan looks like it woill only hold about 5 or 6 quarts. Any Help would be graetly appreciated. There is no dipstick on the engine!
Peter
buickanddeere
05-02-2007 17:49:39
 Re: JD 435 diesel in reply to Peter Campellone, 05-02-2007 16:23:05
Get a universal fit dip stick and mark it 'Full" on the oil line after adding 9 quarts, a new filter, running it for a while then letting it sit for 5 minutes.
JD@Antique Acres
05-02-2007 17:09:21
It holds 9 quarts. The dipstick should be on the right side below the blower. It is a bayonet style with the tube protruding about 8 inches from the block.
G/MAN
05-02-2007 16:51:46
If there's no dipstick, there has to be some other method for checking oil level. Does it have draincocks on the side of the pan for checking the level, as were used on many other Deere tractors? If so, fill it til oil dribbles out the top-most draincock. I'm a little curious how you're estimating what the pan will hold. As far as that goes, some engines have oil levels that keep the full oil level ABOVE the pan rail, with the block creating the rest of the reservoir. You can probably trust the I&T manual, as they're normally condensed versions of factory service manuals.
Peter Campellone
05-02-2007 17:30:28
 Re: JD 435 diesel in reply to G/MAN, 05-02-2007 16:51:46
There is an opening for the dipstick on the right hand side, but it is missing. Didn"t think that the oil may be higher than the oil pan rail. Thanks,
peter
G/MAN
05-03-2007 13:26:22
 Re: JD 435 diesel in reply to Peter Campellone, 05-02-2007 17:30:28
A truck shop or Detroit Diesel dealership/distributor should be able to get the right dipstick for you. I'd take along the engine serial number and/or arrangement number, though.
JD@Antique Acres
05-03-2007 15:28:10
 Re: JD 435 diesel in reply to G/MAN, 05-03-2007 13:26:22
The correct dipstick is no longer available from Detroit...been there done that.
Glen in TX
05-03-2007 10:27:29
Did you try JD parts for one? There are lots of individuals out there with NOS parts too. I have some NOS JD dip sticks but would need a part number for the 435 to know.
JD@Antique Acres
05-03-2007 15:36:07
 Re: JD 435 diesel in reply to Glen in TX, 05-03-2007 10:27:29
That engine is pretty much all Detroit.
Dipstick nos. are 5121219 5125561 for early and late.
Glen in TX
05-03-2007 18:12:21
 Re: JD 435 diesel in reply to JD@Antique Acres, 05-03-2007 15:36:07
JD dip sticks I have are AT14696T and AT14698T and not sure what they fit?
