4850?
plowingmachine6030
05-02-2007 11:33:02
Howdy,i'm looking at a 1986 4850 2-wheel drive. The tractor looks real nice,and has 7200 hours on it. I'm told it dynoed 225 horse. It's never been overhauled or had any transmission work done,but it doesn't show any signs of needing anything. The tranny is tight and shifts smoothly through all gears. The motor has very little blowby and i'm told doesn't use oil. Starts good too. I would like some information on this tractor and this series of tractor. Never had any of the sound-gard's,my newest tractor is a 1973 6030. Will this tractor pull with the 6030? I'm not sure what mine is running,but it runs strong. Was overhauled three years ago. I will use this 4850 on the same 7-20 plow as the 6030. Any info on the tractor and the 50 series in general would be great. Thanks. Chuck
Howard H.
05-03-2007 08:30:42
 Re: 4850? in reply to plowingmachine6030, 05-02-2007 11:33:02
Dad has a FWA 4850 - it is a great tractor. We've also got two 6030's and there is no comparison in how much nicer the 4850 is to work with.
Maybe comparable in raw HP - but NO comparison in how you'll feel after a long day in the Soundgard cab versus the old 6030... You'll think you've gotten an office job, if you've never had a Soundgard cab before! ha....
Howard
PreciseFarms
05-02-2007 20:01:01
I've spent a lot of time on a 4850 and two 4955s. Had the 48 had MFWD, I don't doubt it would have pulled with or even outpulled the 49s. It was a little harder to start than the 55s but it was really a very reliable and efficient tractor. It had 38" rears and the extra-wide rib fronts. That size rears, though slower on the road make a very big difference in pulling power. One of the 49s had 38s and the other 42s. The 42s were faster and made for a better ride but the shorter tires on the other caused it to noticeably outpull it. The 48 would pull the same 25ft. Do-All as the 49 and you could pull it just as deep and drag just as much dirt with the boards. The only drawback again was the lack of MFWD when turning with the Do-all down to try to eliminate tracks ahead of the planter. Anyway, the one and only 48 I've run was a favorite.
G/MAN
05-02-2007 15:57:03
There were some initial issues with the 15-speed powershift and they later updated the clutch packs and flywheels and went from 3/8" clutch-pack/flywheel hardware to 1/2", etc, but I would think an '86 would have come with the good parts from the factory. If it's running 225 horsepower and hasn't had the tranny gone into at all, it probably hasn't had its guts pulled out or anything. Same goes for the engine. It's probably had good maintenance and care. 7200 isn't a ton of hours, but it's not uncommon to find the compression to be getting low, some blowby, etc. by the time you get into that hour range. I don't know why, but I've never seen oil-consumption to be a serious issue on Deere engines, even when they're plumb worn out. I suspect that when dealing with turbocharged engines at least, the positive pressure in the cylinders when the piston goes down on the intake stroke keeps the oil "pushed" down and doesn't let it work it's way up past the rings.
John Jenkins
05-02-2007 12:21:15
The 6030 will outpull it but the 4850 will be much more comfortable to operate.
santa-deere farms
05-02-2007 12:00:41
chuck:
i had a 6030 and traded for a 4850 two wheel drive.the 6030 might have a little more horse, depending how much it was turned up. but the extra gears in the power shift will make a difference. the only thing to check is the engine bearings. i replaced mine at 5200 hrs. but it wasn't necessary. just a precaution. check the vent on the water pump in case the water pump leaks it don't get in the engine. you will be very pleased with the 4850. john
