Delco 24V starter experts?
wilamayb
05-02-2007 09:14:30
I recently saw a Delco 24V starter that sort of looked like the 24V starter that was on a 730D that I previouly owned. The starter in question is a 37MT series 300. I was pondering the question that upsets everyone so much.
I have a 720D with an awfully tired pony. It is a loader tractor and is called on to be started for short durations. The pony is a little difficult for convenience reasons. It is not a show tractor and is for work only! I live in TN so its not so cold as to need a pony.
I do have another 720D standard with a pony start that is very original and will stay that way, so dont fret.
As always thanks for the help.
I never tire of hearing all of the reasons I should keep my pony, so please, could someone also post those again? LOL
Mike M
05-02-2007 10:41:51
 Re: Delco 24V starter experts? in reply to wilamayb, 05-02-2007 09:14:30
I'm going to go one farther and say ditch that old 720 and get something more modern for a loader tractor and you won't regret it.
buickanddeere
05-02-2007 09:36:27
I seen an ebay ad for a 40MT starter/bracket. Nobody ever installed too much starter power or battery capacity. A true 24V or 24V start/12V run is ideal. In a warm weather area. A 12V system if built with no compromises and if the compression release is used, it should work fine. And the comp release always should used by the way when starting. As previously stated, keep all the starting engine parts together, clean, dry, safe and identified. I don't know how so many people have starting engine problems? We have three around here that get used on a regular basis with a minimum of annoyance.
mjbrown
05-02-2007 13:05:31
 Re: Delco 24V starter experts? in reply to buickanddeere, 05-02-2007 09:36:27
I had a 24V starter rewound for 12V for my 730D and with two twelve volt batteries in parallel with monster cables and useing the decomp. I had adifficult time starting it. It worked in summer OK with 16V (two 8V in series). I went back to 24V and it starts great. Mike Manly had a set up to do it with 12V but I never got it to work well. Maybe the archives go back far enough to bring up his posts on the subject.
