JD 3255??
RMinVa
05-02-2007 05:09:19
My neighbor has a JD 3255 with a little over 6,000 hours on it. The tractor has a dry clutch and has had to replace the clutch several times.
The problem now is slipage but doesn't seem to be from the dry clutch. example: pulling a earth pan in 4 wd the tractor will just stop pulling when the pan is cutting but never smell any smoke from the dry clutch. From what I saw there's no way a dry clutch with that kind of load that would slip and then start to pull again. I guess there's always the first time but I figure that kind of slippage would destroy a dry clutch in a few minutes. If the pan is lifted a little all four wheels will go back to pulling. He's been moving dirt for 4 days like that.
I know little about this tractor but it does have a high/low shifter that can be shifted while on the move. Does this system have some type of wet clutch behind the dry clutch that would stop all wheels from turning if it was slipping? Any ideas on what this problem may be?
low budget
05-02-2007 05:39:52
 Re: JD 3255?? in reply to RMinVa, 05-02-2007 05:09:19
Yep, the HiLo is slipping. Could be caused by low pressure in the trans hydraulics, but disks are probably fried by now. Does it slip in both speeds? Its held in Hi by hyd pressure and in Lo by spring pressure.
RM inVA
05-02-2007 14:14:57
 Re: JD 3255?? in reply to low budget, 05-02-2007 05:39:52
Yes it slips in both high and low sometimes.And sometimes it doesn't. That's the puzzling part. But he did say it got worse as the tractor warmed up.
Thank you for your reply.
low budget
05-02-2007 19:04:58
 Re: JD 3255?? in reply to RM inVA, 05-02-2007 14:14:57
Got to thinking, it could be a rear seal on the engine or transmission seal letting oil on the clutch. It could slip until the oil burns off without smoking the clutch. This would explain it slipping in both Hi and Lo. Then again could be both Hi and Lo clutch packs are shot. This model is really just a utility tractor with a lot of engine, I dont think its really built for the job your doing.
