1951 John Deere G Hyd. couplers
Bob in NC IA
05-01-2007 21:24:58
My "G" has the hydraulic plugs. I just purchased the hydraulic couplers for it. I flipped the side lever down but can't seem to pull out the plugs. What am I doing wrong. I posted this a few days ago but must have done something wrong because I don't know where the post went. Thanks for your help.
Jon Hurley
05-02-2007 18:10:37
 Re: 1951 John Deere G Hyd. couplers in reply to Bob in NC IA, 05-01-2007 21:24:58
I have a '51 model A and the PTO does have to be on for the hydraulics to work. I had the same problem with mine in getting the plugs to come out. Once I got them to moving, they haven't been a problem since.
You can check out my A at www.jdsmodela.com
Bob in NC IA
05-02-2007 16:55:57
Thanks for the help. I got the side pins pulled out with a vise grip. I didn"t get a chance to hook up a cylinder yet. Does the pto need to be running for the hydraulics to work? Thanks again. Bob
Almrm
05-02-2007 05:01:44
The plugs can get stuck if not used for a long time. They get painted in, rusted in etc. The lever needs to be in location to release the locking pins. The horizontal position is unlock and the vertical position is lock. Use penetrating oil and try to free up the lock pins. They should pop out with the lever horizontal. If you cannot get the lock pins free with the plugs in, they can be pulled out in the lock position the same as the couplers would if you break away from your implement. Use vise grips and twist them first, then give them a pull. Use tape or cloth under the vise grips jaws if you want to protect the knurl on the plug from damage. If you cannot jerk them out, the G will. Tie it to something and pull away. When the plugs are out you can clean, lube and free up everything. Note: make sure PTO is off and HYD lever has been cycled both ways to aviod the classic John Deere oil spray bath.
Of coarse, you can disassemble everything and get them out also.
Hope this helps,
Mark
john deere 70
05-02-2007 05:01:36
Make sure the pins under the flat piece of metal that is under the lever come out . Some times the pins stick in. The plugs should pull out ,you might have to turn them to get them free.
