G/MAN
05-02-2007 16:09:10
Re: JD G tractor starting in reply to grwrench, 05-01-2007 17:45:48
If it has a Power-Block with no petcocks, the stock starter might have to work fairly hard to roll it over, particularly if it's not in the best of shape. The Power-Block will add cubes and bump the compression-ratio pretty substantially over the 4:1 or so factory "G" compression ratio. If it was a "puller", there's also the possibility that it has been stroked, which will add more cubes and may bump the compression even further. My buddy has a 700+ cube GM, and with the engine freshened and nice and tight, it was all a 4430 starter wanted to roll it over, WITH petcocks, but I doubt your project is in that ballpark as far as cubes. I found the solution for him while messing with my own "G", which was purchased sans starter. We had a complete takeout 8400 engine in the warehouse from an engine failure in a tractor, and it still had the gear-reduction Denso starter on it. I found that it would fit and work on my "G", and subsequently loaned it to him for use on his big puller. It has a MUCH easier time than the 4430 starter ever did, and probably weighs half as much, or less. Those Deere/Denso gear-drive starters are NOT cheap over the counter at the Deere store - around $425 or so for part number SE501403, but you might be able to find a used one. I've heard tell that there's a gear-drive starter used on some Bobcats that will also work, but I don't imagine it's much cheaper, and I'd be curous to see if it's got as much "grunt" as the starter Deere uses to crank those 8.1s.
