520 LP help!!
RGG
05-01-2007 11:47:43
Does anyone know how to restore the carb adjustment needles back to factory on a 520 LP? We're pretty sure we've got them all out of whack. Tractor starts good, runs good on flat surface, but when you take it up a decent hill it seems to bog down and lose alot of power. Read another thread on here about checking the spark plug gap (should be .015-.020? .030 too much?) so we'll check them too. Carb was just cleaned and rebuilt last year for retoration. It's probably got less than 10 hrs. Thanks for any help!
Ben.So.Tex
05-01-2007 17:28:42
 Re: 520 LP help!! in reply to RGG, 05-01-2007 11:47:43
You may want to open the load needle up alittle. It is located on top of the carb lying flat between the barrels and it should have a pin throught the head of the nut, rotate it with a screw driver by pushing on the pin about one round and see if that work. Good Luck Ben
Glen in TX
05-01-2007 12:18:59
On spark plugs .015-.018" recommended for LP engines of any brand for smoother idle and running. Natural gas engine plugs can be run at .012-.022" because with dryer vapor fuels the larger gap is not needed and will just cause rougher idle and running when gap on plug wears more.
Slow idle adjustment is done by setting lever at slow idle and then using a rubber band or something to hold the throttle lever on stop screw. Adjust to 300-600 rpm with stop screw. Then adjust each needle for max rpm. Take rubber band off and run throttle up to fast and back to slow and and if accelaration and deceleration are not smooth open idle needles more. Reset slow speed back to 300-600 rpm.
Set fast idle bolt under dash for lever for 1460 max for 520.
Average load screw setting for 520 is 1 1/8 turns open.
Did you mess with threaded throttle rod ends too. If so you'll have to get it adjusted too a half hole from entering and then governor arm should have throttle 1/8" off the stop pin.
Oil level in air cleaner correct? No grease or mud daubers nests in air cleaner, stack or intake pipe. Vent on back of vaporizer/regulator clear not plugged with bugs nest?
I&T JD-16 shop manual, JD SM2015 LPG service manual, 520 LP operators manual OMR2052 or OMR2075 for 5208100 and up. JD tech pubs 1-800-522-7448 or Ed 812-537-4622.
