37 John Deere Model A Block and Head Ohio
Austin P
05-01-2007 11:40:57
I have a 37' JD Model A Unstyled with a cracked head. Previous owner put straight water in a couple years back and cracked the head and block over the winter. The block is repairable, but I do not believe the head will be. Any recommendations on repair shops in Ohio to have the head looked or any good recommendations to look for a used head?
Jay Chrisman
05-04-2007 02:40:33
 Re: 37 John Deere Model A Block and Head Ohio in reply to Austin P, 05-01-2007 11:40:57
American Engine welding in Dayton ohio, I have had 3-4 done here
Mike M
05-01-2007 11:51:10
Columbus Cold Weld can fix some cracks , but it ain't cheap.
There are several used parts places like Wilson Farms,Harlan Wilson,Roberts Farm Eq.,Dengler's alot of these advertise in greenmagazine and 2 cyl.
Austin P
05-01-2007 12:55:54
 Re: 37 John Deere Model A Block and Head Ohio in reply to Mike M, 05-01-2007 11:51:10
Thanks Mike M. I have used Columbus Cold Weld before and you are exactly right. They are not cheap. I will check out the other places you mentioned.
