Alliance tires
ppeter
05-01-2007 09:01:45
Hello,
The best price for replacement rear tires 15.5X38 at my local dealer is for Alliance brand. They are about $80 each cheaper then Firestones and Titans. Does any one have any experience with the Alliance brand?
Duane Larson
05-01-2007 20:30:30
 Re: Alliance tires in reply to ppeter, 05-01-2007 09:01:45
ppeter,
One other aspect - Alliance provides a tread close to the old style 45 deg bars like on Goodyear and Firestone. Some folks like this pattern better than the 23 deg Firestone tires (which came along after New Generation), or the modern short bar-long bar pattern. I have some Alliance tires and so far no problem, but I bought them because of the tire tread pattern.
CPeter
05-01-2007 20:08:41
I recently replaced the tires on a 420U (14.9x26) Not much selection, so had to go with Firestone. The local ealer treated me fairly and gave me excellent service. Yes I paid a lot of money for tires on a small utility tractor, but the $1,020 I feel was money well spent if they give me half the service the last set of quality tires did. Changing loaded tractor tires is enough of a pain that I don't want to do it again.
CPeter
Roy Suomi
05-01-2007 17:31:21
I've used them..Priced right , Tough to mount , sidewalls are real stiff..They worked OK
low budget
05-01-2007 11:28:52
Had a set of Alliance on my 4020 when I bought it. Wasn't real impressed with the tires,not that many or heavy of lugs on them. Had one patched and the tire man commented they had a thin sidewall. When it went flat a second time, I replaced them with Generals which I liked. Guess it all depends on how you plan on using the tractor. For light use a cheap tire might be OK
Mike Aylward
05-01-2007 11:20:09
PPeter, if it were me I would spend the extra money and get the Firestones. The Titan tire would not be any better quality-wise than the Alliance. And to be sure, ply ratings are not equal. I have worked on tires for many years and some 6-ply tires are much heavier than some 8-ply. The fact that there is only a few pounds difference between the Alliance and Firestone tells you as much. The rubber quality will be much better in the Firestone. I do not sell tires, either. Odds are you will NEVER see a worn out Titan or Alliance tire because the quality simply is not there. You get what you pay for. Mike
dirtjockey
05-01-2007 14:41:23
 Re: Alliance tires in reply to Mike Aylward, 05-01-2007 11:20:09
we road out tractors alot and the firestones which although last longer than the titans are in comparison not worth the extra money over the titans. any LSB's are garbage over pavement. We change tires about every three years and have burn about every maker of tire to the cords. It's the balance of price over length of work life.
Tx Jim
05-02-2007 03:40:00
 Re: Contenental tires in reply to dirtjockey, 05-01-2007 14:41:23
dirtjockey,I took my tractor to local tire dealer several years ago to have new rear 18.4X38R tires installed and when I picked it up it had Contenentals on it. I had never heard of them. They are long bar/long bar and show little highway wear and no sidewall cracking today. I custom bale hay and do some plowing so mine have quite a few road miles. I'm guessing the tires have about 2500 hrs on them but I didn't write down hrs. Tx Jim
Ben.So.Tex.
05-01-2007 10:33:38
I put a set on my 720 about 3 months ago, Yes they were about $80.00 cheaper and they are 8 ply where the other brands were only 6 ply. So far I like them. My 2 pennies Ben
buickanddeere
05-01-2007 09:55:50
Shipping, installation, storage & markup is about the same on any of the same size tires. You are purchasing $80.00 less rubber, fabric and production.
ppeter
05-01-2007 11:06:02
 Re: Alliance tires in reply to buickanddeere, 05-01-2007 09:55:50
buickanddeere,
I don't understand what your saying.
From your experience are Alliance a low quality tire. Or is this just your general opinion?
According to my dealer the Firestones and Alliance are about 5lbs apart. For a 200lb tire I would call that insignificant.
buickanddeere
05-01-2007 11:44:03
 Re: Alliance tires in reply to ppeter, 05-01-2007 11:06:02
My local tire dealer won't sell Alliance tires even for people who want them. He would rather loose a sale than have a customer unhappy with product. $80.00 each on such a large purchase and spread over the operating costs of several years? You are saving nothing. The question should be, "Do I want Firestone or Titan radials". Where do you think the savings of $80.00 a tire is coming from when the other identical tire costs are the same?
Mike Aylward
05-01-2007 15:56:50
 Re: Alliance tires in reply to buickanddeere, 05-01-2007 11:44:03
You are right, Glen. I have been around tractor tires for many years in farming, turning tires into feed bunks, and currently cutting tires for pulling tractors. I have noticed the construction differences in tires for years. Most of the second line tires are "price tires" and odds are a bead will break or the tire will split way before they would ever wear out. And to respond to another poster's comment, the Firestone tires are not "long-short" bar. They are "long bar-long bar". I would absolutely NOT put any kind of "long-short" bar on ANY tractor. Not only do they look bad but they will not hold up or road as good as a long bar-long bar tire. I have seen too many of these in my time to say differently. A good friend of mine runs a tire shop and he has told me the same thing. He keeps the second line tires because someone is always a price shopper but he says they are the most expensive tires in the long run. They simply won't hold up and if the tractor sets for long periods it just compounds the matter. Stick with the better tires. They will be the cheapest in the long run. Mike
ppeter
05-01-2007 12:30:14
Thank you for your input. $80 per is about 15% difference in the total replacement cost. If I were getting 15% less tire for that less cost that would be fair. But If I were getting 40% less tire that would be another matter. I consider saving $160 significant when considering that these tires will be going on a 50yo tractor that may be worth $4000 on a good day. Radials are way to expensive for me to consider.
I am very familiar with retail, marketing and manufacturing. One thing I know for certain that the price of a product most often has nothing to do with the cost of production and distribution. You cannot judge the quality differences of products by their price differences.
Any way, have a great day and thank you for your help.
Peter
Dirtjockey
05-01-2007 14:50:07
 Re: Alliance tires in reply to ppeter, 05-01-2007 12:30:14
That is true good quality is high and junk is also high masquerading as quality. Good quality will always be worth the price in the end. The trouble is HOW do you tell whats good even from a reputable brand like firestone. Do I hear a ford explorer rolling over? Every company has a skeleton just dying to jump out of the closet.
TxFarmer84
05-01-2007 18:17:18
 Re: Alliance tires in reply to Dirtjockey, 05-01-2007 14:50:07
Most of the Ford Explorer problems came from underinflation or overloading, or a combination of both. Firestone just had to take the blame.
buickanddeere
05-01-2007 21:45:02
 Re: Alliance tires in reply to TxFarmer84, 05-01-2007 18:17:18
Most of those Firestone SUV tire failures occured on southern interstates, in hot weather,after several hours traveling at high speeds, with heavy loads. The SUV owners wanted trucks that rode like cars so Ford installed light duty tires and ran them at low pressure for "comfort". Why is anybody suprised there were tire failures?
