4440 or 4450?
frmerjoe12
05-01-2007 07:44:34
i'm considering the purchase of one of these as a second tillage tractor. have always had internationals,but my neighbor let me borrow his 4250 last year and i loved it. which of these two would be better to buy? are they basically the same tractor? i have a budget of around 30,000. transmission doesnt matter as the 4250 had the power quad and i liked it. have heard the 15 speed powershift is great. any info on these two models would be great. reliability,fuel use,anything like that. thanks in advance. Joe
Ben Gubbels
05-01-2007 19:17:17
 Re: 4440 or 4450? in reply to frmerjoe12, 05-01-2007 07:44:34
Buy a Ford it will blow them both away. Ford Tw-20 that is a real tractor. Seriously though go with the 4450 it is overall a beter tractor with a little better hp.
G/MAN
05-01-2007 17:13:10
The 4450 doesn't have quite the "rep" the 4440 does, but that's just because the 4440 was outstanding in every category and so much above and beyond what IH was building at the time it came out that it quickly became a legend. By the time the 50s rolled out, IH had redeemed itself, to a small extent, by introducing the 88s, although they too were hardly in the same class with a Deere 50-series. There's a ton of options available on the 4450 that you couldn't get on the 4440. 15-speed powershift, Caster-Action MFWD, Investigator II instrumentation, a much-improved HVAC system, the 50s all had the later 466 engine with the crank-driven oil pump - early 4440 has the cam-driven pump that tended to wear the cam and pump gears after lots of cold starts with cold, thick oil, etc. etc. etc. The 50s also have a better SCV design with Pioneer couplers replacing the JD couplers on the 40s, and have better dust covers and coupler drains, etc. And 4450s have a thermostatic fan clutch, so the cooling fan doesn't have to run full speed all the time, which frees up some horsepower and improves fuel economy. It all really boils down to what you want and what you want to spend. Either tractor was top-of-the-line when it came on the scene.
dirtjockey
05-01-2007 14:15:01
I have worked on both. I am a fan of the 4450/4455. over the 4440 for several reasons. The trans is the first. Much more user friendly in that it has more field working gears. Water pump design is better and also the standard hydraulic outlets. If your row crop like us then you'll appreciate the 50/55 series if not then the 4440 will be just fine. Althought for hauling grain I would rather use the 4440.
dirtjockey
05-01-2007 14:17:01
 Re: 4440 or 4450? in reply to dirtjockey, 05-01-2007 14:15:01
powershift to powershift comparison.
Stonecreek
05-01-2007 12:56:53
There's little difference in the 40 series and the 50 series. The rated horsepower difference may be about 10 hp, but the variation in individual tractors often exceeds that. (I once owed a 4640 and a 4850 that, for practical purposes, were equal in drafting power.)
What counts in an older tractor is condition. Given equal hours and condition, you can buy the 40 for a little less than the 50. But buy the individual tractor that appears to have had the best maintenance and the least abuse.
The Powershift is a good transmission, but then so is the Quad Range. Again, look for the best individual tractor regardless of its series or transmission.
mjbrown
05-01-2007 08:57:32
Similar questions have been asked here recently so I think you can do a search and find a lot of info. I don't own either but the other threads said both are great tractors with the 50 being a bit greater.
