From your original thread... "engine speed remains set. It does not increase with load and causes engine to stall." The engine speed is not SUPPOSED to increase with load, just hold steady at the speed already set by the hand throttle. Does it have a functioning "tach"? If so, what are you seeing as the fastest speed it "revs" to without load? With no load, does the engine "throttle up" with the lever, from idle speed to "rated high idle speed",or just remain at idle as you advance the throttle lever? With the engine shut OFF, and the throttle a little above idle, does the linkage between the governor and the carburetor move freely by hand? If the engine is "throttling up" as the throttle lever is advanced, but "pulls down" as soon as load is applied, I will once again tell you I suspect a fuel flow "issue". Even an automatic spark advance that is stuck or otherwise defective will affect it's power, and how it "picks up the load". If the linkage to the carb is NOT stuck, and the engine remains at idle as the throttle is advanced, it sounds like a broken governor spring.
