How to check oil on a John Deere B
Skattracker2
04-30-2007 18:38:49
I can"t figure out where to check the oil on my 1941 B. This is the first two cylinder I have owned. I am a Farmall man, but I really like this little tractor, I just am not familiar with them. Please help. Also how do you time these tarctors? I am very good at timing a four cylinder by ear, but have no clue when it comes to a two cylinder.
Thanks
Skattracker2
05-01-2007 18:19:14
 Re: How to check oil on a John Deere B in reply to Skattracker2, 04-30-2007 18:38:49
Thanks to all of you for your help. I did buy the shop manual for the tractor and I will try all your tips. Thanks Again
James Howell
05-01-2007 10:19:09
third party image
Above is a picture of �whatever� was in the oil bath.
Be sure to check/change the oil in the oil bath cup under the air stack.
The previous owner assured me the fluids had all been changed, but did not say changed to what!
My 1940 B has the oil level check on the LEFT side below the flywheel.
My 1943 B has the oil check on the RIGHT side below the pulley.
GeorgiaHayFarmer
05-01-2007 03:04:20
Remember that when checking the oil look for it to be thick (not runny). Smell it. Make sure it doesn't smell like gasoline mixed with oil. My 1950 B will sometimes get gas in the oil through the carb if I forget to shut off the fuel valve at the tank. So this is just a reminder to always shut the fuel off when you get off the tractor so that when you go to check your oil you don't find gas mixed with it as well and then have to change your oil and filter. After changing my oil a few times I finally learned my lesson.
Scott
Gary from Muleshoe
04-30-2007 19:26:59
My 1940 B has the oil level check on the left side below the flywheel. Did they change this to the right side in 1941?
Will P
04-30-2007 20:28:26
 Re: How to check oil on a John Deere B in reply to Gary from Muleshoe, 04-30-2007 19:26:59
Nope, it is still on the left for 1941. Some people just open there mouth too quick.
johns48jdb
04-30-2007 18:59:19
don"t unscrew the wrong screw. the screw that adjust the oil pressure is right there in the same spot so don"t mess with it. you should have to turn the screw but just a little bit and should turn freely after you break it lose. i tihink the oil adj screw is surounded by 3 other screws. sorry don"t have my books here to look at tonight.
Will P
04-30-2007 20:26:53
 Re: How to check oil on a John Deere B in reply to johns48jdb, 04-30-2007 18:59:19
No it is not, the oil pressure adjustment is in the crankcase. The oil check is on the left side, not right. You are right for the LATE styled. Not the EARLY styled.
JD@Antique Acres
05-01-2007 06:55:08
 Re: How to check oil on a John Deere B in reply to Will P, 04-30-2007 20:26:53
I don't know, but I have a '43 that has the oil check on the RIGHT side below the pulley.
Will P
05-06-2007 20:34:34
 Re: How to check oil on a John Deere B in reply to JD@Antique Acres, 05-01-2007 06:55:08
My 43B is on the left.
Will P
johns48jdb
04-30-2007 18:53:46
right under the belt pulley on the right hand side, look for a hex headed screw that you just back out a little ways and see if it starts dripping. i would never think of starting a tactor i didn't know anything about without checking the oil in it, unless the owner says its ok. you need to buy the owners manula, shop manual and service manual for your tractor. some of the others guys wil give you the number to call and the manual numbers. to time it - turn your mag all the way to the left and leave it snug. rotate the flywheel until the holes in it are perfectly level and then go back to mag and turn to the right until it clicks. tighten it down and your done. check the points while your at it to see if they are burnt. there is a hole in the cap that should be open to the air. you'll enjoy your deere. give yourself time to get use to it. don't get off of it while its running and in gear.
JD@Antique Acres
04-30-2007 18:53:10
On the right side below the belt pulley. There is a check valve, turn it out, if oil drips it is full. If not add oil til she drips.
